Is 7 Bolt Crank Timing Belt Gear Same As 6 Bolt?
I know when I did the 6 bolt swap on my 2g I used my old crank timing gear and it works fine. As far as the balance shaft gears I am not sure because I used the BSE kit but I don't "believe" they are any different.
    • Sdcryan1
