Intermittent alternator problems
Lucas1079
Apr 17, 2025
Miami, Florida
Hello, I have a problem with the alternator of my Eclipse G2. I've tried to look for a topic about it on the forum but I haven't found anything similar. My alternator normally charges 14 volts right after starting, but after some time, even with the car idling, it loses charging voltage and drops to only 11 volts. Has anyone experienced this? And if so, can you help me solve it? I suspect it might be something related to the voltage regulator, but I decided to seek out experts to clear up the doubt before removing it. My car has a Fueltech ECU, would this be a problem too?
Time for a new alternator - the voltage regulator is part of the alternator. These cars eat alternators for lunch, so look for a lifetime warranty unit.
BTW, it's 2g (as-in 2nd generation). G2 sounds like some new knockoff Eclipse, and I actually had to look it up to make sure it wasn't.
The Alt can be fine cold and then fail when its warmed up. I had a NEW Reman OEM unit do this. it was perfectly fine for about 10 mins and once warmed up it shut off producing low lower. it happens and on the bench testing they could not simulate this either. it had to be on the car for it to fail and some shops do not understand this part LOL
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
