Interior lights, cd player, Pwr. Windows and locks won't work!
S_Ranger
Banned Member
761
6
Aug 30, 2004
ca, Central America
What the hell? Brande new battery, it starts, headlights turn on but none of my accessories. Car won't lock unless done so manually, windows won't roll down, cd player doesn't come one. Can someone help me out? Thankyou
check all fuses...take them out with a needlenose pliers and look at them. You should see your problem right there
Check the 80A Alternator fuse in the engine bay. If your at the passenger side wheel, its the one all the way to the top right corner.
I forgot about disconnecting my battery when working around my alternator and blew it. Power locks, seat belts, radio etc all died.
It's a fuse. By using a multimeter you can find a blown fuse where you don't necessarily have to remove each one. For the flat bladed type fuses there are 2 contacts on the top of each. Turn the ignition on (to energize more circuits) and with the multimeter set to read voltage and at least 12 volts, measure the voltage across each fuse. If any have any voltage at all, they are blown (since a fuse is supposed to be a short circuit). If no voltage, measure each fuse contact to ground. If there is the exact same non-zero voltage on each contact, that fuse is good. If both contacts read zero volts to ground, that fuse may be good or bad and you will have to remove it and check it's continuity separately.
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
