General Intake options 1gb (1993)
93eclipse113
Aug 15, 2021
Palm Bay, Florida
Hey, i'm looking for intake options for my 1g (stock tune)Should i stick with a 1g maf and aluminum pipe? Can i run a translator to a 2g maf without tuning ? im just looking for a better look than this rubber pipe, it's old and beat up and if not what could i do to run the stock maf with an aluminum pipe and where could i get one?
A translator and a 2g maf and no tuning....no.
Think of it like this. If you change the input to the ecu, in this case the mas, you need a tuning solution to account for that. A maf translator is a tuning solution that replaces the stock maf and uses a gm maf. Btw it's not a very good solution compared to others.
Do you have a route you would recommend for me to take, i'm looking to use this car as a daily. Eventually i want to push 20ish psi with the supporting mods which won't be too many since i had the engine rebuild by Sidewinder DSM. What Route should i take tuning wise? id be completely new to tuning and it seems there are many options when it comes to DSMs
The general concensus for most us is dsmlink.
What you probably need to answer for yourself is what you need the car to do. Not a list of parts mind you.
For just your immediate question you can get an intake pipe if you want. If you're solely in this for looks that's fine but you may end up doing something else and it would require a change. Keep that in mind.
Check this out.
I recall being able to run the 2g maf without tuning if you also added 550cc injectors. I believe they cancelled each other out and could didn’t have to tune.
It's close from my understanding. Ive not done it personally.. Anybody attempting this should probably have an understanding of tuning still so they know why stuff does what it does.
Though stapl3 post is correct. Ecm link is always a great idea for further headroom. I always tell people maintenance first then ecm link.
2g made 560 great set up I bypassed it and got a gm maf and translator before it got to that set up to try out for myself .
There's really nothing to undestand about it. 2g maf and 560s cancel eachother out within a percent. 560s require zero deadtime adjustment. Put a 2g maf and 560's in and drive off. Done. Immediate 17-18% more headroom with no compromises.
They cancel out because you're telling the ECU that it's seeing less airflow, which makes it deliver less fuel. The bigger injectors cancel this by flowing more at the same duty cycle. The side effect, however, is that now the ECU is on a lower load table with more timing. May be a good thing on race gas, usually isn't on pump gas - especially on the already aggressive 1G timing map. It's 2021, get DSMlink and go speed density and tune correctly for your mods.
For reference, this is maf comp adjustment when I was on 2g maf & 560's. Not too far off so I'd assume it would still run.
This graph is misleading. You had to add that much airflow because your fuel system is not calibrated correctly by about 5%.
Ironically the more you push it the better off you are with that timing skew. But the CAS can be tweaked a bit and it's no different from whats been going on with using safc's for decades now. 'Link for 1gs has only been around for like a dozen years I think.
How did you come to this? Think I had rc 550’s not 560s now that I think about it.
Peak VE is at ~1800hz which you have your airflow adjustment at +5.5%.
So when tuning maf, you want to be at 0% adjustment at 1800hz?
To sum this up, you’d increase global by ~5% and bring the sliders down? Is that correct?
The sign of a well calibrated car is WB=AFRatioEST and boost=BoostEst, both at peak VE, with the mafcomp slider value at zero.
You just happen to be at 1800HZ during peak VE.
Yes. You can adjust global OR base fuel pressure as they are dance partners. I always adjust the base fuel pressure.
On race gas, that extra timing really woke these cars up back in the day. We ran 11.0 @ 126 on a VPC, 550s, 20g, 272s, and no wideband. Stock 1G 7 bolt, head and intake manifold. Just plain old C16, leaned out, and 25+ degrees of timing at 30 psi. On pump, different story. You're not running over 20 psi without lots of knock on most setups. Yes, you can mess with the CAS and other tricks, but again when DSMlink exists, there's no need for the band-aids anymore. Also, we did have chip tuning before Link came out for 1Gs too.
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
