intake manifold
You may want to get some bracing put in where it cracked as well.
If you need a place to do the work for you talk with Brian at Erbified Motorsports. He's great to work with and very reasonable with his labor rate.
If you don't want to do a sheet metal perhaps the cast Magnus is the way to go.
For cast manifolds the hawver is a pretty good option. They have some dyno numbers up now for it. They are priced really good also, 550 bucks.
