Installing tranny
snowboarda10hal
32
Oct 8, 2006
west newfield, Maine
when i install my tranny, is their anything special i have to take in to cinsideration? Im guessing the way i will go about it is, use a jack and jack the tranny up so i wont have to kill my self by lifting it, and just bolt it up. Is their any kind of allignment issues i will have to watch for?
The only thing you are going to have worry about aligning that might be a pain is the pinion shaft into the clutch assembly. Other than that you are going to be able to see where everything else needs to go as you are putting it together.
If Your Doing; Doing It By Yourself It Will Be Close To Impossible, I Would Dare To Say Invite Some People Over For Some Pizza/ Tranny Wrestling. Its A Pain The :beatentodeath: But The More Merrier. The More People Pushing And Pulling The Better. Good Luck.
yes its so much easier when someone helps. i just put mine in last night..got frustrated aligning everything up using a floor jack for half an hour so my brother and i decided to just lift the sucker up...got it aligned in 5 mins.
