ECMlink installing rywire can't get ecu to communicate with ecmlink
Dirtrider412
5+ Year Contributor
60
3
Jan 7, 2018
Coraopolis, Pennsylvania
so I got a rywire engine harness with my tax return I pulled the chassis and fuse box harness behind the firewall under the dash but havnet cut or extended any wires. mpi clicks with ignition but ecu won't connect to ecmlink. but I do want to say I'm super disappointed in this rywire harness and the customer service there as well Ryan acted like he was annoyed that I wanted to ask a few questions. and it's missing things that it didn't list in the website. like I had to repin ecu pin 4 so i could get o2 hooked up. but anyway . blinkers don't work but headlights do, mpi clicks then clicks again after ignition is turned off just looking for ideas any input would be appreciated. dont have alternator pos stud hooked up either. was going to get ecu on before I worried about charging.
the rywire harness had a random unlabeled 2 pin connector bundled with the ecu plugs and I had to cut off the weird plug off my new 700 dollar harness and run them directly to the obd port and wire in just pin 1,10 and the ground to pins 1 and 2 on the ecu. kinda more than they advertised to get this harness working....
like I said i figured it out no thanks to rywire. thanks anyways.
I like having my obd in a better spot now anyway. it's by the stereo now much better access for my data cable
    • Sdcryan1
