Installing head
Scraggybeard
40
Jun 8, 2013
Maple Grove, Minnesota
I'm re-installing head after replacing gasket i've read thatI don't want any pistons at TDC, any reason I can't turn crank counterclockwise to set all pistons at half mast or do I need to turn clockwise? Also, any other tips on installing the head? Thanks in advance.
You can turn counterclockwise because there is no belt or anything connected yet.
I would recommend arp headstuds.
It helps to have the timing tools too.
I also recommend ARP head studs. Only advise I can offer is go slow, and do it right.
Properly torque the head down. Triple check timing marks. Make sure the mating surface is clean. Its a fairly straight forward job.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
