GSXTCY
- 999
- 0
- Jun 17, 2002
Pottstown,
Pennsylvania
Nah, just a friend that wants to drive an awd for a day!
Dude, I swear I didn't see your post first--Originally posted by FourG63 97GST
why dont you 2 just get a room
j/k
. If i remember correctly, I was here firstBTW I registered June 2002 and you registered July 2002. So technically I was here first!Originally posted by FourG63 97GST
. And nobody carries it in stock I had to special order mine from I.N. because that was the closest place to me with that part. Just in case your curious its part #MD300835
Originally posted by RaysTsi
And there is no way that removing the whole radiator is easier than removig the fan.
Manifold. And it was surprisingly easy-- all the nuts came off with no problem. It was a little tedious with the ones on the bottom, since you have little room to work with and have to stick a wrench in between the runners, but it wasn't hard. The manifold gaskets (yes, there were two, is that normal?) looked good, so we just reused them.Originally posted by RaysTsi
Doug- Did you just take the dp off or did you take the exhaust manifold off?
