Installed GM maf ans translator need help
98_tsi_
51
Feb 6, 2013
Lebanon, Tennessee
I put a GM maf on my car today and when I started it up it idles terribly....so I turned the WOT counterclock wise until the idle seemed normal and stable. Then when I give it gas it misses or sputters. Mine has 4 knobs beside each other.... BASE WOT BASE WOT. Then the AUX is up at the top left. Is there any advice on how I should set it up?? First time using a maf translator and the rpm wire is not hooked up. I am unsure of what version I have I think its the 1.3, I have everything set at zero and all the switches to off.
