Inline fuel pump? Can I do it
livedsm4g63
1,214
152
Mar 1, 2008
Auburn Hills, Michigan
Well I was out in the garage with my dad and we came upon a walbro he picked up from "our in" at walbro. The part number is a F20000, which I found out has a bigger inlet then the GSS series. He got the pump to run for a boat motor, and Im thinking the person we had make it, made it for an in-line for that reason. Is that an in-line fitting on the bottom? Take a look at it and tell me what you think. I think I would have to put it inline because the way the bottom is shaped. But Im not sure if I should, and if its even possible with this pump. Let me know what I should do oh wise ones.
Ps. I found a person using it as a in-tank on evoM and they say they see 290lph at 40psi.
Right now I only have a regular 255 Hp in-tank and 1050's. I Plan on going over 450 so I want to add some more fuel.
  • Wanted 6 bolt NT water pipe
    • chrisman287
