Injectors vs Water Injection
heavypedalmuzic
86
Jan 28, 2004
bronx, New York
Hey,
I've been reading treads on water injection and its benifits which have been compared to those you'd get by adding more fuel or race fuel.
can it be said that instead of getting bigger injectors, that we can opt for water injection which in many cases is similiar in price to injectors?
in a month or so ill have enough $ to get dsmlink. i want a good/safe tune while running my evo 16g from its current 15psi to about 18psi but not sure if i should get w. injection or 660 injectors. i guess at some pt. in time we would like both, but which would you suggest to be the 1st mod of the 2?
I figure others out there may be wondering the samething.
Thanks
get injectors first. the water injection is great to reduce knock and engine temps, but you need to consider a couple of things. first off, you cant rely on water injection to increase boost without a logger to constantly see if your engine is safe. secondly, keep in mind that ANY time you run your higher boost setting you are going to have to have the water injection on and you will be going through it fast
