Injectors maxed at 10psi??
sidewaystsi
188
16
Aug 8, 2008
st. germain, Wisconsin
I took a log today, for some reason exel is sucking it right now and wont let me upload so ill just do this. Third gear from 2,000rpm to 6,500rpm. I notice at 6,031rpm the INJD is at 95.3%!?, timing is 22, 0 knock, o2 reads .74v. My mods are in my profile, but im only at 10psi of boost! Their stock injectors but they shouldnt be working that hard at just 10psi, they should be able to handle more that that, right? Anyone have any insite as to why their almost maxed out?
well if you are on stock turbo...it is wierd to have the IDC that high ...
but if you're on a big turbo, those stock injectors can get maxxed out quick
10 psi on 14b doesnt need as much fuel ..
GT35 turbo on 10 psi flows way more, thus needs more fuel...thus maxing your stock injectors...
Yea im still on the 14B and im sure it could use a fuel filter change. The only boost leak i got is from the throttle body shaft seals(big suprise) but its pretty small. Maybe the injectors themselves are clogged up? Also i notice the fuel pump voltage drops alot at WOT, need to do that rewire when its not so cold out. Would the pump losing power make the injectors work harder?
Did another boost leak test yesterday and found that the bov is leaking like the titanic. Must have just started right after the last boost leak test. Thats probably the cause of the high injd huh?
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
