Port work maxed out stock injectors!?!?!?
Hoodwink
Sep 8, 2011
Riverton, Utah
Ok so I have a 98 gs Eclipse with the 420a and it is fully built. Forged, ARP studs, cometic head gasket, bored out, 1mm oversized valves, ported obx intake mani, 60MM throttle body. It has a T-3 Turbo with a 50 trim exhaust wheel and 60 intake.
So to the issue: I only have a 7 psi spring in my wastegate and want to push 7 on the stock injectors as many claim to have done with no problems. Only My wideband gauge is saying that under boost I am at 14.1!!! This is with an adjustable fpr and a vortech 12:1. I have no boost leeks. The timing is perfect. Does this sound like maybe the port work and all the extra airflow mods have maxed out what the stock 190cc's can handle?? I'm reading up that the stock ECU can handle up to 310cc injectors as long as you have a way to adjust idle fuel pressure. If this is the case then I can simply buy a set of accell 310cc's for $170 and plug and play right? Then I should be more than safe to push the 7 pounds boost and get the a/f ratio into the 11.5 range hopefully. Any input is greatly appreciated! Maybe I have faulty stock injectors? Anyone know what the Ohms should be on those? AAAHHHH! :banghead:
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
