Injector Sizing
dherron
87
4
Jun 12, 2004
Uhrichsville, Ohio
Ok so here is what I have, Walbro 255, 2.3 Stroker, Stocker Turbo Plan to upgrade, Maf-t, AFR,Full Exhaust, What size injectors should I get to support around 450 500
http://www.rceng.com/technical.htm
Good tech on selecting an injector for a particular application, with a handy calculator on the bottom. All of the variables to plug into the calculator are explained in the article.
For example, according to that calculator with 500hp, 55psi of fuel pressure, 80% max duty and a BSFC of .6, you're looking at 876cc. I think their calculator err's a bit on the high side, but it gets you close.
According to that calculator, 720s would be at just over 97% duty cycle at 500hp and 55psi. That doesn't leave much room for error (or injector deposits ;) )
