injector sizing
boostin2005
Sep 13, 2006
clarksville, Tennessee
will injectors from a toyota supra fit into a dsms fuel rail? Like the mid 90's model supras running after 95. Found some but not sure if they will fit my car and was just wondering if they are the same, they look like itd work.
kelvinb said:
supra injectors are side fed, while ours are top fed. i do not think they will work with the stock fuel rail either way.
YOU are incorrect. They are top feed, but I don't know if they would work. You can use the late 80's and early 90's, if I remember right 1988 and before the injectors will drop right in, 1988 and newer will work but they have the round injector connectors.
so you are saying mk4 supras have top fed injectors stock?
  • Wanted 6 bolt NT water pipe
    • chrisman287
