Resolved Injector leaking from rail
coloradotuner
118
11
May 20, 2013
Schererville, Indiana
Te My 2g has developed a leaking injector Cyl #3 from the fuel rail, I just replaced the O-Ring into that goes into the head last year, It looks like it is leaking from the Rail seat now, it is only seeping when car is off so as I can tell, under load it may go away. I did my research and I see that Torqueing the fuel rail will not fix the problem since they the injector "floats" between the rail and the head when pressurized..
is there a easy fix? new o- ring?
On the 1997 DSM stock injectors is it common for these o-rings to leak if so are the part numbers are they the same for both seats???
