Ludejim
- 62
- 10
- Apr 28, 2010
Centennial,
Colorado
Hello all,
This car is too much fun! and now that I have had some fun, I really want to get this thing dialed in to perfection. I am following this guide here: Tune Speed Density W/O MAF.
If I am reading this document correctly, after setting up ECMLink and all of my Speed Density (SD) sensors the first thing to do is tune my idle. I cannot for the life of me get this thing to have a steady idle. Short Term Fuel Trims (STFTs) and Long Term Fuel Trims Lo (LTFT) are constantly on the move. I adjust my deadtime and global fuel to compensate, but it seems they end up fluctuating too much to lock in to what I would consider stable.
When the car first starts, the idle seems to be stable (running open loop because it just started), but it is not hitting the target Air Fuel Ratio (AFR). The AFR it is hitting isn't dangerous per se, but it is not what is set in ECMLink. Once the car has warmed up, 190 degree coolant level AND it switches into closed loop, the idle really starts seeking. You can see my O2 sensor oscillating, and you can see my STFTs follow the oscillations. The ECU seems to be doing exactly as told, but the idle RPMs vary greatly and the STFTs seem to change too much to allow a stable idle. My first question I guess is, should the O2 be oscillating faster?
To answer the first response that is going to be thrown out there, yes I have read Terry's Talon Troubleshooting Tips #3 - Fast Idle (aka. Idle Surge) and I have performed the following as instructed by that guide and else where:
Regards,
James
///////////////////////////////////////////////////////////////////////////////////////////QUESTIONAIRE////////////////////////////////////////////////////////////////////////////////////////
1). Any boost, vac, or exhaust leaks?
Boost leak tested 5psi above your max boost with no leaks? My boost is set at 16 PSI, I tested up to 30 PSI without any leaks
2). Verified mechanical timing? Yes, Cam sprockets dowels at 12 o'clock and timing marks line up in the middle. At the same time, the crankshaft and oil pump timing marks are lined up perfectly.
3). Verified base timing? Yes, 5 degrees BTDC
4). Ignition system
COP or Stock Coil: Stock
Wire brand and Age: NGK, Less than 2,000 miles on them
Spark Plug brand, type and Gap: NGK BPR7ES .028
5). Motor health (Compression Test)
Cylinder 1:160
Cylinder 2:145
Cylinder 3:160
Cylinder 4:160
6). Performed basic throttle body adjustments?
Idle Switch: Simulated in ECMlink, performed TPS adjustment and ECMLink sees .63 volts at 0% throttle and 5 volts at WOT
Throttle Cable: Yes, just enough slack that the throttle doesn't stick
TPS: Yes, as mentioned above, I performed the TPS adjustment within ECMLink
BISS: Tried, but can't get ISCPosition to stay at 30. Grounded diagnostic pin in using ECMLink and set the BISS to get the ISCPosition as close to 30 as I could. ISCPosition wanders trying to keep idle stable.
7). Compression ratio - Stock
8). Any known bad sensors or brittle wiring? uh, don't all DSMs have brittle wiring?? haha in all seriousness, there are some brittle wires.
9). Any DTC/CEL codes? No
10). Electrical system
Car off (not running): Working
Car running: ECMLink battery voltage reporting 14v, drops to 13v when under load (for example when rolling up both windows and they both reach the closed position but your are still holding the buttons)
11). Base fuel pressure and injector values
Base Fuel Pressure: have tried both 37 PSI and 43.5 PSI (of course I adjusted my global fuel in ECMLink when trying both base fuel pressures. I adjusted the fuel pressure using my Aeromotive FPR)
Injector Size (cc/min): FIC 1150s
12). Properly calibrated and configured wideband sensor
Sensor Brand: Innovate LC-1
Calibration Date: N/A
I'll calibrate the wide-band once I can get the car to idle with the stock narrow band O2.
13). Type of fuel
Type: Gasoline 91 octance
14). Watched ECMlink how-to videos? About a million times, My eyes are now immune to them
- Boost Leak Test - tested up to 30 PSI. I am fairly sure this is not the issue.
- Cleaned Throttle Body (new gaskets in between TB and intake manifold and between TB and intake piping)
- FIAV block off plate
- Throttle Cable Adjustment
- TPS adjustment
- Vacuum lines deleted.
- EGR Deleted
- Adjusted BISS
- Purchased new Idle Speed Controller (ISC). No change. Tested ISC coils, tested good! The newer ISCs resistance should be somewhere in the 40 ohm range from what I have read, that is where my new one sits. Here is a video of the ISC operating, honestly looks broken as hell to me, but I don't know what a working one looks like and cant seem to find a video of a working one.
- Pulled ECU to check ISC drivers and corrosion. Everything seems to checkout. I have attached photos for inspection.
- I've gone to the extent of pulling the timing cover off to verify that the crankshaft, oil pump, and cam timing marks align when cylinder 1 is at TDC.
Regards,
James
4). Ignition system
Cylinder 1:160
Cylinder 2:145
Cylinder 3:160
Cylinder 4:160
13). Type of fuel
). This is covered in
