AlexSza
- 73
- 0
- Mar 23, 2009
ec,
Wisconsin
Ive held off posting about this but now its just getting under my skin
. After this build I kept finding little things that would set the idle off, but now after completely sealing EVERYTHING, (no boost leak, vac lines are perfect) it still manages to surge. It does not surge when I start the car, it idles high then drops after a few seconds. When i go to drive it, clutch in gas it and start to move, it will begin to surge but only between about 1,100 to 1,300 or 1,400 RPMS.
Is it okay to drive it with this surge, or will it cause problems down the road, the motor has only 11 miles on it, but about 5 hours of tweaking while running.
Could I drive it with the annoying surge until I can get the accessories for a tune
And another note, I have an aftermarket FPR, it works just fine but the barbs inside of the tapered ends are always cutting my lines... the lines are braided but there is NO way they are getting through the fittings that were provided, any help would be well appreciated.
i could maybe load a video off of my phone if it would help any!
. After this build I kept finding little things that would set the idle off, but now after completely sealing EVERYTHING, (no boost leak, vac lines are perfect) it still manages to surge. It does not surge when I start the car, it idles high then drops after a few seconds. When i go to drive it, clutch in gas it and start to move, it will begin to surge but only between about 1,100 to 1,300 or 1,400 RPMS.Is it okay to drive it with this surge, or will it cause problems down the road, the motor has only 11 miles on it, but about 5 hours of tweaking while running.
), the ECU started managing the idle and the surge started.
