idle surge
JFatch1890
332
3
Oct 31, 2008
Stratford, New Jersey
Whats up guys.Alright well got my car back together.This was happening before i took it apart.Soon as i start it up it idles at about 3 grand for a few seconds then drops and starts bouncing around 1 & 2 grand.No matter if its warmed up or not.I read about the biss and seen that it said something about elevation.Well I'm at a high elevation so could that influence it that bad.Also there's a wire on the left back of the intake when your looking at the motor from the front that someone spliced a wire and stuck it where there's suppose to be a plug.I pulled the wire off and the car idled without bouncing but still idles high and My luck its something i probably need LOL.And yes i do have a big a$$boost leak LOL I can't even build boost hardly but i haven't got that far yet.But i cant see that being the problem.Any info that would help would be appreciated and sorry this is so long.I read the forums and vfaq.Id just like to get more input on it before messing with the biss.Thanks
Start Here
Terry's Talon Troubleshooting Tips #3 - Fast Idle (aka. Idle Surge)
You WILL find the solution to your idle surge here. Also type "idle surge" in the "search page using Google" function at the top of the page. Check the vfaq and faq again. This is a notorious problem with many different causes.
And yes, a boost, vacuum, fill in the blank leak WILL cause this problem. Do a BLC and follow the list.
For me it was a healthy combination of vacuum leaks, bad isc and fiav.
Good luck and happy motoring!
