in need of dip stick and tranny bolts
mnNice
71
Oct 28, 2009
Duluth, Minnesota
does anyone have these two things laying around? in the middle of my build they have seemed to be misplaced. it would be great if someone was so generous as to give them for the price of shipping:) but i can understand if you want some money for them. just let me know thank you
-Mark
It'll be faster if you just run to your local hardware store like Ace Hardware and find 10mm x 1.25 bolts. Can someone second the size of bolt? Not too sure though.
Someone around must have a spare dipstick around here..... Hmmmmm
i had that problem when i replaced my transmission this past winter. if you can find out what size they are then just go to your local hardware store and pick them up. thats what i did. i lost two during the replacement process and it cost me $3 for the new bolts. good luck and as for a dipstick just go to a junk yard and see if they have one for your car. hope everything works out for you
-Mark
i have a dip sick i will send you! pm with your address and i will send it to you i might have some bolts laying around. is it the bolts that bolt the tranny to the block or flywheel to clutch that you are needing??
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
