2G Improving FWD Traction, Quaife Way to Go?
Ferp
159
14
Sep 14, 2014
Edmonton, Alaska
I've done a good bit to improve my FWD traction such as putting on some adjustable coilovers and removing some weight in the back. I've inquired into LSD's for the 2nd gen GS-T but I can't find any solid reviews for the Quaife LSD which is what I'm interested in. I wanted to know if I'll see a large improvement on launches and less wheel spin through first and second gear. I also wanted to know if it makes much difference in winter driving. Thanks, I searched around but couldn't find a thread with first hand experience that answered all my questions.
Heck YA it's the way to go!!! :) along with solid prothane motor mounts. And a good strut setup,and to top it off full prothane bushing kit. Then the most important part driver mod!! Learn to slip the clutch and hit your gears :) I wouldn't do anything with a gst without getting a lsd!
When you install the Quaife, it will be like driving a different car. How you take corners will change a bit. As far as traction goes, it would be hard to find a negative aspect of having the LSD versus the open diff.
    • george bromwell
    • pma1123
    • Sdcryan1
