FIBA M - EC17PSE
Supporting Vendor
- 6,772
- 5,197
- Nov 1, 2008
Orlando,
Florida
So im fed up as i just got done with my timing belt fired it up and and re calibrated my wideband (lc-1) and at idle im ok 14.5-14.7 but when i cruise im at 12.5 sometimes a bit lower and WOT im about 9.8-10.3 and ive done 2 boost leak tests and found nothing, all the o2 sensors are just over 1 year old and the thermostat is about 1.5 years old and its had 3 coolant flushes in about 2 years, i thought it could be the CAS trigger cap thing inside the cover but ive been told its not that.
So what else can i look for or do to get this corrected as im getting bad milage and it was not like this before the change of the belts! Should i look at a rad cap or ingition wires? Would any of these cause issues of running rich???
Someone please give me a list of everything i should check and i will check them all again if i have to or read power or volts or anything to get it running how it was! Also im pretty sure its not the o2 as im not loosing any power and ive read thats a symptom,
PLEASE HELP ME i really dont know what to do or check next
