I'm missing a throttle body connector.
MidShipCivic
718
9
Apr 22, 2005
Orlando, Florida
I have a wire by the throttle it's blue and I have a single prong pin.
What does this prong do? File attached below.
It's probably your throttle plate closed switch. It tells the ECU the throttle is fully closed and cuts fuel depending on conditions. On the 1g's the switch is separate from the TPS. With the 2g's it is integrated with the TPS.
So then in order for it to run properly I would need a 2G TPS then? I'm getting a high and surging idle when the car isn't warmed up and I'm thinking it's the FIAV but I'm not totally sure. I've tested the ISC and it's 30 ohms across.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
