2G Throttle body missing "E" and "A" nipples?
Dryppical
126
29
Apr 5, 2023
East Helena, Montana
On my 1997 gsx, I only have the “P” outlet on the throttle body. The “E” and “A” nipples are gone. I deleted emissions so there is really no use for them I think. Is there anywhere that sells those pieces or should I weld them shut or something?
If you deleted your emissions then there's no use for them. Cap them off or plug them up somehow or you'll have a good sized vacuum leak. All 3 of mine are capped off and it runs perfectly fine. You said the nipples are broken off, if that's the case then yes just weld them shut to seal it up.
Thanks! That’s the answer I was looking for. Just wanted to be sure I didn’t need them for anything before I weld them shut. The pic I used was one I found to show was I was talking about as I am not near the car at the moment. I appreciate the help
