Ignition Timing
KeithAZ
90
4
May 20, 2015
Gilbert, Arizona
I just picked up a 90 TSI with an unknown set of cams. I will be finding out what they are here shortly once I pull the VC off.
I understand the factory manual calls for 5° BTDC. Will cams affect what I should be setting the base timing too? I understand there is adjustable cam gears and have read a lot of opinions on if they are needed or not. Some say you can get away without using and others say there needed to find tune your car. Are they needed?
I am a bit confused after reading multiple posts and would like to clear things up.
Thanks
Regardless of what you do with the cams always set the cam angle sensor to 5*btdc with the timing terminal grounded that way the ecu/logger actually reads the correct timing. There are times when you wouldn't set it to 5*, but that's for advanced users.
Okay thank you I was a bit confused. As far as once I find out the cams I have, would came gears be a good option? The car lobes pretty hard so I am thinking at least 272's+, also has dual valve springs and titanium retainers.
As I would want to change the timing belt and all of that at the same time. I also read you would only want to adjust your can timing on a dyno.
Yeah it would be best to play with the gears on the dyno so you can see what it changes in he power curve. You can move them around to improve spool and such. Be careful though, depending on the pistons and cams you can have problems with piston to valve clearance. Bang for your buck, stay with the stockers. I have a set of aem true times and all I can say about them is "they're pretty"
Yes I understand. As your spark timing isn't going to be directly affected by having cams. I was over thinking it way too much. Thanks.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
