Ignition timing? problem
Rob90AWD
Aug 14, 2011
New Orleans, Louisiana
I'm trying to help a friend with a mostly-stock GVR4. I think I know what's wrong but I wanted to bounce it off the experts. I'm the original owner of a 90 Talon TSi AWD so I know my way around unmodified DSM's pretty well. His GVR4 was running fine
His description of the symptoms:
"Bob sets timing to 5 degrees. Later I leave, car feels as if it were dragging, like boost was being produced but wasn't going anywhere. After 10 mins I find myself unable to accelerate, pulling to the side of the Road using the car's momentum. It starts to overheat and I quickly turn it off. I pop the hood and see smoke and bright orange coming from the exhaust manifold and turbine housing. I call Bob, he tells me to loosen the cam angle sensor and rotate a lil counter clock wise, I do, and take it for a test spin, same thing, no power but boost gauge is showing full boost. Then he tells me go the other direction, to put it Half and half between the adjustments, I do and bam prob solved. Power is back, no more dragging feel. And no more over heating. Then on the 40 min drive home the speedometer decides not to work."
Note that last sentence, about the broken speedometer. I suspect his VSS (vehicle speed sensor) is causing the ECU to retard his timing because it is saying "0 MPH" all the time. I couldn't find anything in the forums/FAQs relating VSS to timing. The service and technical manuals say the ECU uses VSS for ignition timing but doesn't say how. It's possible Bob just set the base timing incorrectly (forgot to ground the timing terminal?) but I doubt it because Bob is a long-time well-established DSMer himself.
So my questions are:
1. Am I on the right/wrong track about the VSS?
2. Other ideas besides base timing?
3. My friend wants to drive this thing 4000 miles round-trip in a few days. How nuts is he to try it without nailing this down first? (I say 9/10.)
Thanks in advance for any thoughts/help.
I am uncertain on how VSS works with Timing, but when mine broke the car drove perfectly fine for about three weeks till I got one. Just that the car seems to idle lower than it should when idling at speed, like coming to a stop light. Obviously its' because the ECU thinks car is stopped, but other than that, no difference felt whatsoever.
The only way to tackle the timing issue is to do it right, and try again. Ground what you have to ground and set it. Maybe he left the CAS loose?
Thank you Chicken Patty. I hadn't considered that maybe it wasn't tightened down enough. Definitely agree he should shoot the timing again, properly, as a first step. Cheers.
I'd definitely consider that, just do it all over again and make sure it's done right, can't go wrong with that. :)
It's clear it's a issue with Ignition Timing since moving it back or forth fixed it. Just needs to be done right now.
This response is for the archives: The base timing was very retarded. Problem solved. Thanks Chicken Patty for the replies. Cheers.
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
