Ignition problem?
Threeve
Oct 20, 2009
St. Catharines, ON, Canada
Hey. Problems started like last week. Car wouldn't turn over, poked the starter solenoid and it started fine. Next time I tried it wouldn't start again, then it turned over for a sec before my starter fell apart.
Since then I've replaced my starter and battery(battery started deathing out too). It turns over fine like crazy now, but it won't get started. I'm stumped.
Have you checked all the plugs on the power transistor, coil pack, the cap thats connected to the coil pack?
I read a random post from someone on another forum saying a bad coolant temp sensor wouldn't allow your car to start.
Can anyone confirm if there's some truth to this?
Yesterday, whilst checking compression(gauge quickly went to 60 for all cylinders except 2, which quickly went to 30psi) my new starter stopped working. Now it just makes a weird noise..
Not sure why the hell it would start doing this, I haven't changed anything relating to it, and it was turning the engine over fine during the compression test. However at the end of turning the engine over it would make the noise for a second that it now makes all the time.
I believe this is just on 1g's
What kind of compression tester are you using? autozone?
Is your Battery fully charged? If the battery volts are LOW the starter can make a fast clicking sound.
Using an Innova compression check gauge.
Not sure if I'd call the sound the starter is making a "fast clicking", but I recharged the battery to more power than it had before easily turning the engine over.
It definitely has enough power.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
