ignition problem
92tsibacker
62
Apr 11, 2006
raceland, Louisiana
When i put the key in the ignition the gauges do not come on nor does anything else that usually is triggered by the ignition. Today i put a 255 walbro fuel pump on and when i put it back in the car, some kindof sensor or valve broke off that clips to the top of the plate on the gas tank. But i still wanted to see if the car would still run, so i tried starting it an it would just turn over. So i tried a second time an the problem began.
Sensor clip...As in maybe the sending unit wiring? Or the fuel pump wiring? If it would just crank and not start it sounds like you messed up the pump wiring.
As for everything else not working now...Check all the fuses, etc. As well as the battery posts and connections. It's probably something stupid.
i got it thanks.. it was the engine fuse busted an the ground was broken. I dont know why the pump wasn't workning i took it out and put it back in and it's doin fine now. thanks
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
