zeekster777
- 523
- 0
- Dec 31, 2009
valley center,
California
I have a 1998 GSX, I am going to get some cams. Some one said I should do gears at the same time. Is this true?
Well if you feel up to degreeing the cams then yes I would suggest cam gears but if your not interested in degreeing the cam in perfectly and spending the time and extra money into the job then just run the stock gears.
To properly use adjustable cam gears, you need to:
-Find the 0° setting for your car. This requires using solid lifters and a degree wheel.
-Then from there, know what moving each cam actually does. (Read).
-Finally, you'll have to actually adjust the cam gears, do a pull, adjust again, etc. until you get the desired results.
-If you're going to be adjusting them to the extreme (for some reason) you'll probably also want to clay to find valve clearances.
Or you can do what 90% of people seem to do, and that's install the cams straight up on their pretty new cam gears. It does add some bling to the engine bay.
I like the sound of the bling to the engine bay, and this will not be my DD. I would like the option of being able to dial the cams in. So its really a win win, but some one said they get loose over time. That I do not like.
