Idle Surge problem! Can't figure it out and I've searched!!!!!
1997_GST
81
Jul 10, 2009
Mansfield, Texas
Okay, so i have a 97 GST that i did a 5-speed swap on. The car runs, I drove it from Mansfield, TX to Electra, TX, about a 2.5 hour drive,. The car has a idle surge. And it's annoying and makes me mad!!! LOL It had a SAFC hooked up to it but i removed it to see if that would change anything and it didn't. I've tried different ecus and still does it.
The surge is like between 1100 rpm and 1800 rpm... and if i give it gas it revs fine but after i let off the throttle it sticks at like 2500 rpms for a split second then goes back to the surging...
If i drive the car and like barley hold it in 1st gear it like changes the throttle on it's own...but does fine while normal driving at highway speeds...
ANY HELP WOULD BE APPRECIATED AND REMEMBER I DID SEARCH ON THIS AND COULDN'T FIND ANYTHING THAT MATCHED EXACTLY MY PROBLEM....
THANKS!!!!!
:sneaky:
a moving isc does not mean the valve is functioning. which is why i re described what you already mentioned. and a good/bad isc will always have carbon deposits on it.
ps. biss asjutment will not drop engine speed on a surging motor LOL
yes, but a "good" isc can be hindered by chunks of carbon build-up...
Do your self a favor and ditch the FIAV and emmissions all together. Best thing i ever did to my car.
+ (insert random exagerated number here!!!) this helped my idle surge issue ALOT! :thumb:
The only thing that link doesn't cover, that ended up being half the answer to my surge, was the throttle cable adjustment. Everyone overlooks that..
My car is doing the same thing, I assume it's something I touched while doing my EVO III 16G Swap (Intercooler Piping) ### it wasn't doing it before. Or it could just be a coincident that my ISC went out at the same time. I'll report back soon what it was.
hell yeah. it should cover that... but i know to check that if somethings up with my idle
Oh it's not a matter of HOW to check it, that's easy. It's the simple fact that you NEED to check it, and the reason behind it.
Ya so when i took my old isc apart i found the whole inside was like glued together from carbon build up and crap from sitting so long i guess... But i have 2 extra to try out and see if it fixes my idle surge!!
I had a similar problem. IAC. or MAF are common problems. Try cleaning the MAF but make sure to get the right cleaner some say DO NOT USE MITSUBISHI. otherwise if those dont work I noticed that if you have you TPS down too low it will cause an idle surge.
Alright this is something noone has considered which is a good sign in the 2g world(since it's biggest downfall was the infamous crankwalk)
Now, my 2g nt spyder had an idle surge. And I checked everything you guys mentioned previous to my response. But one day. I cold started and BAM! Belt pops off the harmonic balancer. And it hits me. My "idle surge" was actualy my crank walking drastically.
LOL my motor did crankwalk but on the previous owner that is a buddy of mine and he had the motor completly rebuilt and it was automatic and something was wrong with it so i converted it to 5 spd and now it runs good! :)
Nice LOL. Stick is the way to go
