CAN'T FIGURE THIS OUT!!!! (I've searched)
1997_GST
81
Jul 10, 2009
Mansfield, Texas
Okay so here's my story... I had a 97 gst and It got wrecked so I bought a 96 shell and switched the ecu wiring harness that goes out through the firewall... I swappe the motor and everything.. I went to start it and with the maf sensor unplugged, it idles but really bad... And when I plug the maf up it just dies... Or it will start up the immedately dies.. I can't figure out why.. Maybe I have something hooked up wrong?? I don't know!!! Any help would be GREATLY appreciated!!!!
I have tried searching buy couldn't find anything that helped.
I had a similar issue when I forgot to screw in my PCV valve after removing the valve cover. The car actually idled better, albeit roughly, with the MAS disconnected due to the vacuum leak. Check to make sure you don't have a vacuum leak caused by a missing hose such as the PCV valve, brake booster and vent hose at the passenger side of the valve cover. Also, make certain your valve cover bolts are evenly torqued so as not to create a leak at the valve cover gasket. Another place to check is the intake path AFTER the MAS such as the blowoff valve, recirculation hose, intercooler connections and piping, throttle body gaskets, etc. Any unmetered air entering the engine will cause a lean mixture and a rough idle. For the engine to die as a result of a lean mixture, I suspect the leak has to be pretty substantial. Good luck.
