Idle surge & cracked exhaust manifold
LoTekGuru
Dec 15, 2005
Lexington, Kentucky
I've only had my Talon for about a month and it has pretty bad idle surge. I read somewhere on this forum that a cracked exhaust manifold can cause idle surge. My question is, is the crack I'm seeing cosmetic or is the manifold a solid piece of metal so the crack I'm seeing is most likely all the way through, and could be causing a small leak which in turn could be causing my idle surge?
I'd have to say that those are likely pretty serious, but if you want to be sure, you can unhook the vacuum line from the BOV to the intake and suck some Seafoam through the line. If the cracks are all the way through, it'll pour smoke. Also, since those leaks are before the O2, your performance is getting killed. I'd look into replacement right away.
Andy
Either way, the cracks are only gonna get bigger. You should start looking around for a stock 2G turbo exhaust manifold. I haven't heard of cracked exhaust manifolds causing idle surge but somebody correct me if I'm wrong. Good luck.
I would replace the BISS screw and o-ring. That cured my idle surge problems even though DSMs are bad about that.
its about $6.00, you can get them from slowboy racing and you will need a flathead screwdriver. I think its under oem parts. Its round screw by the thottle body on the intake manifold
Yea definely replace that with a nice ported 2g Mani at the least. LOL
2g exhaust manifold
and your idle surge could definetly be your ISC causing the rough idle, very common with our dsms.
DSM ISC motor
www.ebay.com
you can get both things mentioned above
2g manifolds run around $75 for reference.
Good Luck :rocks:
it might be the tps sensor that is out, and those cracks might look cosmetic and not deep, but i were you i would just get a nice 2g manifold.........
Here is a link with a "checklist" of things that can cause idle surge.
If you could describe a little better what it's doing, we may be able to point you in the right direction. At the very least, I would check your ISC motor, TPS, BISS, and clean your throttle body (you can do this with the unit on the car, but for a more thorough cleaning, I would take it out -- i believe you need to take it out to remove the ISC anyway).
http://www.dsm.org/how-tos/tttt/tttt3.html
And might I recommend picking up a set of manuals:
http://www.ecanfix.com/~manualcd/
These are invaluable when it comes to all things DSM repair.
Also, be sure and check out www.vfaq.com and the 1000 most asked questions under the tech section of this website.
And finally the search button above will find an answer to nearly any trouble ever experienced on these DSM's. I haven't been dissappointed yet with my search rresults and I have been using it quite abit with me swapping engines and all.
Good luck!
here is a good VFAQ on properly adjusting the BISS. http://vfaq.com/mods/BISS-1G.html
In my experience, you will need to play around with it a little to find the "sweet spot" -- there's a certain spot that your car will like to idle at, just gotta find it. :thumb:
Also, thought I would mention -- if a few days after you adjust your BISS, the idle surge comes back, it might be time to replace the BISS o-ring. You can buy this from Slowboy Racing -- air will escape out of the cracked/non-existant/deteriorated o-ring and cause all sorts of idle issues. Just something to keep in mind in case your problem persists :)
well i tighten it all the way then it wanted to die on me then i adjusted it till it idles at about 750-800rpm it sounds a better like it not choking as much as it was. but i tried to back the screw all the way out and it just wouldnt come out so i cant tell if the o-ring is bad or not any suggestions on how to get the screw all the way out, it just seems like there is more thread but it doesnt come out anymore
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
