Cracked exhaust manifold
It could create an idle issue depending on the severity of the leak. The front 02 sensor works in closed loop operation, which is at idle/cruise conditions. Open loop is under boost conditions and ignores the 02. Basically the front 02 sensor determines the AFR leaving your engine, sends this information to your ECU, and the ECU decides to either add or subtract fuel. So if the reading at the 02 sensor is not accurate, it won't subtract or add the right amount of fuel.
