thor
- 0
- Feb 4, 2006
buffalo,
New York
hi everyone.
It's been a while since i've posted last. My last Talon (94) came together with the help of everyone here that replied to my last inquirys, and I thank you.
Long story short, my girlfriend was driving it in november and rear-ended someone, which totalled the car. I have since purchased a non turbo 93 Talon for 400 bucks that had a blown head gasket which I have just finished changing.
The problem I have is this: When putting car in any gear, (car is automatic) the car stalls or if it doesn't, it runs real rough at 600rpm. It does NOT idle surge though thankfully. The part I don't get is it idles fine at 750-800. I did have a bad idle stepper motor which i've since changed and cleaned so it's working properly per test specs in manual.
I have set the base timing and Biss adjustment per the manual, and the car idles great. I installed new autolite 63 plugs and wires, and i've checked all sensors per the manual and all are within spec. It does seem to be running rich though. I want to add I changed my biss o-ring too if that matters.
I noticed too that when putting any load on the engine (headlights, ac, blower) the idle drops and doesn't recover much. But like I said, I did have a bad idle stepper motor, so that can't be the cause of this.
could this possibly be a bad injector or fuel problem? I've checked for vacuum leaks with starting fluid spraying on everything and the idle is rock solid. I was concerned that this engine was pretty filthy as I pulled it apart there was a lot of crusty buildup on everything and the head was varnished pretty bad with old oil. the car only has 102k on it. If you are interested, i've documented the buildup of the 94 then the 93 here- http://www.phantomaudio.net/Talon.htm Please forgive my bad commentary.
I have another throttle body and fuel rail to try but i'd like to get this one going and sell the entire engine out of the other car as a whole. I hate not being able to fix something this small after changing a timing belt.
any help is appreciated. Thank you!
