Ideas for crank dowel pin removal
enriquez2000
2,411
1,020
Oct 5, 2014
fort collins, Colorado
So i have a manual crank from a 90 which has a dowel pin and i need it out for the awd swap.
I tried heating it and using vice grips with no luck.
My left hand drill bits dont seem to want to drill into it...
Only other option i can think of is to grind it flush unless i take it to a machine shop and let them try their luck....
Do any of you have any ideas?
Do you have a welder available? If so you could tack weld a bolt to it.
Yeah, it's pressed in, It's not threaded. But, if you can get it to spin it will probably un-freeze it and you'll have a good chance at pulling it out.
Try mixing 50/50 Atf and acetone. Put around the dowel. Wait for it to try to seep in, then get some vice grips and try to get it to spin. Atf/acetone is the best penetrate I know of.
If you have a grinder or metal file, you can create two flat spots on opposite sides for better grip. I have used this method in addition to suggested penetrating concoctions multiple times with success. I would suggest doing this very carefully.
All i have is a dremel... i like the flat spot idea but id have to be super careful if it will even do anything.. was suprised i couldnt drill it
There is a dowel pin on the crank for the automatic which the manual transmission cars don't have. The way to remove that is to pack the hole with grease and hammer a wood block in it. I read that on this forum and tried it. It worked well.
Its the other way around on dsm... manual had dowel.. auto uses pilot bushing instead
At least on 90 through 94
Wat?
