2G Crankshaft Dowel Pin Part Number
Clutch450
252
Jan 15, 2009
Lancaster, Pennsylvania
This should be a quick and easy answer.
On my recent engine rebuild I'm about to put the flywheel back on the motor and put the motor back into the car when I realize I do not have a crankshaft dowel pin to align the crank with the flywheel. :cry:
I go on Extremepsi to order one and I'm not sure which one it is i need.
First theres this one:
EXTREME PSI : Your #1 Source for In Stock Performance Parts
And then this one:
If its neither of these can someone provide a link or part number for what I need.
Thanks!
Neither of those are correct for the crank to flywheel dowell. One is for pressure plate to flywheel, one is for the rear seal housing.
The dealer shoud still have the ones you need worst case scenario, call any dealer, and get a part number them contact a vendor or get one from the dealership.
