2G Crank dowel pin
getusum
116
25
Jul 23, 2006
birmingham, Alabama
Doing manual to auto swap, anyone have suggestions on pulling this out?
You can try:
- Vise grips
- Welding a nut to it (although your rear main seal is close :|)
- Notch flats on each side with dremel and use wrench or vise grips again
- Simply grind it down flat.
Most of these will be difficult because the crank is still installed. Personally I would just grind it flat if vise grips don’t work.
Only thing that worked! Cut off wheel.
I think the proper tool is a pin vise on a slide hammer. You probably don’t have one of those, but perhaps your local parts store has one to lend out. Otherwise, try a little piece of dry ice held against it and then vice grips. You can’t use a torch because of the seal. You could also drill it.
Grinding it off flush seems inelegant, though probably fine.
You could also try a more longer process and drill tap and thread in a bolt long enough to grab with grips or something similar. Then proceed to pry it out with a flathead or small pry bar.
Just thinking outside the box with something I’d do with limited tools and the urge to get it done now
I think I would have just drilled a matching hole into the flex plate before grinding into my crank like that.
I tried that first. Didn’t like the way it came out. I just cut it slow and a little at a time.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
