Ideal Oil Pressure?
ziggo0
774
9
Oct 13, 2009
La Porte, Indiana
I've been combating a massive oil leak (cracked in half rear main) and a bent up oil pan and lost nearly 2/3rds of my oil and came close to spinning 2 bearings. I have an oil pressure gauge but it wasn't hooked up. I went ahead and did that tonight and I'm curious what ideal oil pressure is at idle (cold & warm) and cruising state average (2 ~ 3krpm). At idle it was about 15psi to 20psi, and it would climb very fast when going through the rpm band. I think I've seen it get near 80psi? Weather is shitty so I paid more attention to the road, thanks for the replies.
10-15psi at idle, and increasing approx 10psi/1krpm.
So pretty much, if you see 70psi oil pressure you should be good. If your beating on it and see 90psi, the 'beating on it' part should pretty much cover if your covered on the lube side.
Rob is correct, your oil pressure seems good. You should really get the rear main seal replaced. Any leak is a bad leak.
At idle it shows 40 psi but I beg to differ, I think my sender ground isn't quite right. Before it would show about 20 psi. On a cold start right now it is over 100psi, but drops to 60 while cruising at 65 mph in 5th. I think you are good!
oh I know it...I've been struggling as this is my first DSM, it seems to spring a leak everywhere I look. Just learned the oil pan has to be replaced since it seems to leak no matter what. I've tried 3 different RTV's and a gasket, still leaks! Then I put a wrong bolt into the rear main...cracked it in 2. Went to go somewhere the other day and the door handle snapped off. Is there a DSM fault check list you gotta completely do before the car will like you or something LOL
  • For sale 1g 91-94 ignition coil
    91-94 ignition coil. Good condition. Have the weather pack that plugs into it and the stock...
  • Wanted valve body for 1GA AWD.
    Looking for a valve body for 1GA AWD.
    • kaanevrensel
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
