autronicDSM
- 925
- 6
- Dec 4, 2002
Kalamazoo,
Michigan
Bigger the water reservoir, the longer it's going to take to heat it up and therefore it will cool better/longer.
WR is the cheapest kit that i have run thru but there is not enough space.. the lenght of the intercooler is around 17" (6x8) my engine bay is the same as EVO 3 size... look at my avatarJamiesTSI said:Looking for thoughts and opinions. I'm still waiting on the 90 degree coupling.
Basic set up is as follows:
Stock 1st gen. intercooler
Ford lighting water pump
1.5 gallon resivour
Honda Shadow radiator
3/4 inch lines
I would like to put a water temp. probe in the system, but I'm not sure where the best placement would be.
brute said:It seems like it would've been easier to just clock the turbo to have an up-shooting compressor outlet like a 16g. Then you could just have a 90* turn and like 3" of straight piping.
But it looks great.
But it looks great.
krnbk2 said:I wish I could have clocked the turbo upward... I would have had to run a spacer behind the exhaust mani which would have messed with exhaust/dump tube placement, or not run a waterpipe. both of these options just seemed to be a little too unreasonable for me, so I opted for the "long route piping" which is still less than 1/2 of what a front mounts piping is
and thanks to those with the complments, ill keep everyone updated on the pogress
jaredgsx said:How often do you have to refill it with water? every run?
DSM90AWD said:Can you complete your vehicle profile so we can drool more
