1G I think something bad happened...
Zultane
54
Jun 11, 2013
denver, Colorado
So, I'll make long story short. I randomly got a bad noise in the engine bay today.
After much time, I took off the valve cover... looking at the engine, the far left rocker, on the closest side to the firewall, had came off. Intake cam.
I took off the pieces that holds down the cam. Again, I don't know their name, but I know their function. Well, on 2 of those, they are chewed up, gouged, and whatever other word you want. They are BAD. on the cam, same thing, they are really chewed up.
I didn't take apart the exhaust side, but, visually, everything looked ok. I suspect this would be what was causing my terrible idle, that I haven't been able to tune out.
I was forced to leave the car at my parents who I was visiting. I'll have to go back out there this weekend.
Somebody bear me the bad news, what am I looking forward to? Bent valve(s)? Clearly need new cams, which means springs as well. May as well take the head off and inspect the innards?
Or am I better off buying a new 6-bolt and keeping mine for parts?
Cam caps. And a new intake cam sound easy enough. I'll take the head off this weekend. I still think I have a bent valve.
I'm unable to post pics, unless there's a way to from ab phone that I'm unaware of.
I am just going to buy a new head. Getting this remachined, honed and aligned, plus new cams is going to cost me more then a used head.
I'm not entirely familiar, if someone could please respond before I buy. I have a 6 bolt engine. Are the heads any different from a 6bolt and 7 bolt?
The 3 main differences are
1) 6 bolt heads have the large intake runners
2) 6 bolt heads have .500 head bolt holes for 12mm studs bolts.
3) 6 bolt thermostat housing mount is slightly different from the 7 bolt
Is it me or are we forgetting the big picture as to why this happened in the first place? Oil starvation, oil pump failure, dirty oil, blocked port, etc. replacing the head is a short term fix. If you smoked the cams and caps you have metal circulated around the entire engine and you should be thinking about replacing it.
Exactly. You should find the cause of the lack of oil. The entire motor needs to be cleared of metal shavings, or you will experience another failure down the road.
I bought a used head from a guy today. As for oil starvation, I believe that was a possibility in the past. The oil pan was dented on the bottom. From what I understand, the oil pickup is really close to the bottom of that pan. And when changing oil, I didn't see any metal chunks inside it.
I just bought this car a few weeks ago. Just still finding. And fixing all of the problems one at a time.
Last weekend, I got a funny noise coming from my engine bay, So, I took off the valve cover. Come to find out, a rocker arm fell off. Meaning I have a bent valve. In addition, the cam journals, and cam caps were all chewed to hell. I bought a used head from a guy.
My full intention for this car is to build it as a drag racer. I have a truck, and a daily driver already. Also, it wont ever pass emissions here in Colorado anyways.
Now, instead of putting that head on, and driving it around leisurely, ive decided Im going to pull the motor, and rebuild the entire thing. Because Im tired of these one off things Im finding here and there.
Money isnt much of an issue, (within reason), I take home roughly 850 a week. And my rent is dirt cheap. I have full access to a 1 car garage, any hours of the day, or night I want.
Lets start talking the fun stuff for this build, Internals, Ill upgrade the 14b at a later date. But i'll do all of the supporting mods first.
I clearly want to build the head because I have it off. I ordered some L19 head studs right now, a little early, but extremepsi has them on sale for 40% off right now. With my old 04 gto i had, everything valvetrain wise, i bought from Texas-speed. Texas speed specializes in LS motors, and do not offer anything for DSMS.
What is a reputable company for Cams for these cars? I see at the top right now it says Brian Crower cams, are they any good? Springs, valves, everything, i would like to know what to shoot for.
And because Im taking the rest of the engine to the bench, What options should I look at for the bottom end? How do stroker kits for this do?
Esssentially, say you had 5k to spend to build the motor, labor free, what would you do? You all know more about these engines then I do. I will take any ideas into consideration. Looking for big power, and low numbers at the track.
Also, all of the supporting peices I would need, injectors, fuel rail/manifold upgrades, etc.
Thanks in advance! :thumb:
I am on the same boat as you as far as cams go. I know HKS and Kelford are well known and widely used on dsms.. But i also am wondering about BC cams because, honestly, they are cheaper.
Indeed, me too. I mean, kelfords are double the price to BC. Is the double the price worth it? Or is it just buying "name" brand.
I remember reading something about each brand being different in the performance aspect of each cam.
Im going to try and find the thread (i think it was a thread)..
Brian Crower cams are generally considered one of the least performing cams on the market. Compared to most other cams with the same advertised duration (272, 280, etc) they aren't a very aggressive profile. That's not necessarily a bad thing, but your generally getting less cam for the cash. A Kelford 272 will outperform a Crower 272 any day and that's the reason for the price gap. For everything else, I'd just advise you to dedicate a few hours to researching. Head upgrades can get a little complicated. Partly because you can overbuild the head. You want to use the appropriate parts depending on engine, turbo, etc.
An actual horsepower/ET goal would help. On here, big power could be anywhere from 500-900hp. But here's the basics on the different short block builds: http://www.dsmtuners.com/forums/art...stroker-destroker-long-rod-engine-basics.html
I'd just suggest staying away from stroker "kits". The crankshaft included is sub-standard to a stock crankshaft, and you can buy the other parts individually.
Again, this depends on your actual # goals for the car.
Just found this
"Correct, a camshaft profile is basically a mathematical equation, therefore it can't be copyrighted. Sometimes a company can design and produce a cam profile for a certain engine that produced large gains in HP and torque, then find out it was copied and sent offshore. Because in the "lift" part of the equation you can have identical specs but somewhere past the decimal point it will vary .... which makes it a different profile."
That's referring to copy-cams, like the Delta DKS. It's nearly identical to the HKS 272, but those fractions of a MM are enough to keep them out of a lawsuit.
But when it comes to something like BC vs Kelford, there are actually full MM's and degrees of difference between them, not just decimal points.
Wes:
Im looking at building somewhere in the neighborhood of high 11s, to low 12s, at 6800 ft (the track here is in the mountains} by next years season. I intend on using a holset hx35, or 40, havent decided yet.
I will be doing all of the build myself, minus having the trans staged by jacks. Because Im 50 miles north of their shop.
Again, the funds arent much of an issue, i have another 9 months till next season starts.
If you are Into building a full drag car look into kelfords or gsc cams. They are top notch. You will be well into the single digits before you need to get some real custom stuff.
Springs depend on how high you wanna rev the engine. I guess it depends on whether you are going to stroke it out or keep it 2.0.
At the end of the day it all depends on your goals. Do you want something you can rev out, do you want a stroker motor, do you want a destroked motor (2.1), whatever? What are your goals? If money isn't an issue what is most important to you?
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
