Something Happened i am Clueless Help
dohcGST
48
Dec 15, 2003
Charlotte, North Carolina
i was driving down the road, and i heard a pop and it cut off, and lost brakes and steering, and i got it home started it up and floored it and didng got about 3k, and the brake fluid container lid poped off???? im lost and i need quick help Thanks
Define "cut off". Do you mean the engine cut out or the pop stopped and you lost power steering and brakes?
And when you were driving it, were you pushing it or just cruising along?
Was it making any strange sounds before hand, like a belt squeeling?
With just the info you've given it sounds like a massive failure in your power brake system which works off of your vacuum system, which inturn could cause your engine to stall out. But again that is only a guess based upon some scarce information.
CMF
well i went back outside for further inspection and found that a ic hose has came loose, but i dont understand why the brake cap thing woul dhave came off??? and why i lost my brakes? i dont get it
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
