eddyspaghetti
- 137
- 18
- Mar 27, 2016
san francisco,
California
Hello, I drive a 1997 Mitsubishi Eclipse GSX 7 bolt engine, my cams timing is correct but I wanted to know if my crank timing mark is off?
I manually cranked the engine 6 times before I took the timing belt off and this is where I ended up. What should I do next if its off? The timing belt is off right now, and since this is my first time doing this job, I'm not sure. Am I ok to taking off the cam lock and cranking the engine again? Or do I need to install and tighten the timing belt THEN manually crank the engine? If so how many more times? Any help would be much appreciated thank you
thank you for the help, I really really appreciate it
