i need a new turbo
So many possible issues if there's no play. If you're feeding from the filter housing, there's a good chance you're over-oiling it by sending double the amount of oil pressure the MHI turbos like to see. You can try adding a restrictor to the feed line, but normally once it's been smoking a while the damage is done and the turbo will need serviced to replace the leaking seals.
Also, verify that the oil drain is not pinched or kinked in any way if it's not an OEM metal drain.
Have you thought about stepping down to a 14b? They can be had for little to nothing and like all mhi turbos very durable.
