I have MMCD but is a Scan tool good too?
So you're saying as long as I am able to understand what MMCD is showing me I'm already getting all the info I need?
Not exactly. What I'm saying it that the Scantool can't display anything more than what MMCd does. It could display it faster (more samples/second) than you might be able to with some Palm PDA.
Or it might not tell you as much as MMCd does. Some Scantools only tell you the fault codes and aren't loggers like MMCd.
So you're saying even a good OBD-1 scan tool wouldn't be any more useful than mmcd for troubleshooting problems?
Ok thanks.
What are auto mechanics using when they plug into the OBD port and are able to activate/deactivate windshild wipers and other solenoids etc?
Anybody?
Ok, so if my check engine light comes on should I pull the code with my analog voltmeter and then plug in mmcd to see what's exactly wrong?
One thing I like about the scan tools it says they'll store codes which is good if you're having intermttant problems. Is there a program I can install on my Palm or SD card to plug into Palm that mimicks scan tools? I'm not looking to ditch MMCD at all but wondering if there's any programs that would be worth having in addition to it. Thanks
Sort of. Now I need to either find the cd-rom that I misplaced that explains all this stuff or I need to find a site on the internet that explains everthing :)
