I fixed it!!!
fonzi90Tsi
418
Feb 17, 2012
Bakersfield, California
So long story short I got this car cause the Guy was having clutch engagement problems and tried everything and nothing worked.
Well my turn!
I tried everything in the book on this site and to my dismay nothing helped. Well yesterday I pulled the tranny to inspect everything. Everything looked great as EVERYTHING is new.
Anyways I go to look at the clutch assembly and see that the pressure plate assemble isn't even bolted down! OMG
So I bolt them down to spec. And whala! Goes into gear. Lightly grinds but I need to bleed then adjust the rod.(gotta get more fluid)
Anyways I have one question though. I got under the car to check for leaks and I see that my fork is vibrating?! Is it suppose to do this? If I just lightly push it against the slave it stopped. Will it stop after I bleed the sysytem?
good job! wow.. unbolted pressure plate, that's tough. as for the vibration coming from the throwout lever, is the rod between the lever and slave cylinder loose? bleed and recheck for said vibration.
Thanks bud! I just figured out my problem and posted in my other thread about it!
Man these Dsms well teach you a lot!
  • Wanted 6 bolt NT water pipe
    • chrisman287
