i am able to drive my car safeley
bigbrdf250
59
Dec 9, 2011
SugarLand, Texas
i just installed my new 60 trim turbo and need to get it to the shop, i am able to drive the car normaly to and from there or will i have tuning issues,driveablity issues that will really affected any mechanical parts?? all i did was install a bigger turbo
yes profile is up to date except for the new turbo.
link was for old set up and was still needing to be tuned but close enough, and since then will need to install program on new laptop and try again. i initially did not tune with link as im new to it. thanks
(any one in hoston area wanna help tune???)
can any one answer this post from an earler date(see below) thanks
my car starts but is not driveable yet,, still working on things, but when i installed a t fitting right before the turbo to meter oil pressure i read 14psi at idle give or take depends on idle, and with my 2 step holding at 4800rpms it reads about 50psi no more though.
my feed is from the ofh -4an which looks to have a restrictor in it?? when measuring off a t from the ofh at the sender port my readings are way high, at around 4800rpms im reading around 80+pressure. that leads me to beleive i have some type of restrictor??
my main question is i cannot go wide open throttle cause of the set up so im bouncing at around 4800rpms and reading 50psi of pressure, is this ok and when at wide open throttle on the street will it keep this pressure?? its not smoking and have one of those crap -10an ss lines from extreme.
Whats the WG set for? Watch your WB and take it easy on the loud pedal!
17lb spring
