Can I drive my car
95tclipser
40
Nov 19, 2008
VALRICO, Florida
I recently installed an AFPR and a Deatschwerks 200 fuel pump, everything else is stock, no tuning device yet. Can I drive the car around the block (test Drive)? Thanks.
Sure as long as you set your fuel pressure to 43.5 psi with the vacuum line removed.
Yes. Just set your fuel pressure. But why install that stuff without a tuning or injector upgrade?
Ok, this what happened. my stock fuel pump said I cant' work anymore, so, instead of buying another stoker I decided to upgrade to a bigger pump, then I got an afpr. Tuning(DSMlink) & injectors(950's) will be next. This car has been sitting for 4yrs, hopefuly next year it will hit the road. Thanks for the reply.
