hx35 turbo help
4g63turbo84
614
Dec 10, 2008
ocala, Florida
i just got my hx35 turbo in the mail and i need to know what all i need to in stall it on my car i just got a t3 manifold as will so all i got is the turbo and the manifold. what oil lines do i use were doi get them do i need to change the houseing on the turbo to make it fit or can i just have a custome dump pipe made? if you can pm me some pics of your instal so i can have a good idea please thanks
Well you might want to start at the holset thread... Look at the trubotrader.com for the lines
Just curious did you get it off of a guy with a dodge diesel or did you buy it new somewhere?
If you really did read the Holset thread you would have seen where to get the lines.:rolleyes:
But here just because I'am a nice guy
1.The Turbo Trader
2.Tim's Turbos - Turbo Rebuilding
3.EXTREME PSI : Your #1 Source for In Stock Performance Parts - Oil Feedline Kit (Oil Filter Location): Mitsubishi Eclipse 90-99
As far as the housing thats up to you. If I were you I would go back and reread the Holset threads mostly parts 5&6 they have alot of installs or check out the http://www.dsmtuners.com/forums/turbo-system-tech/313476-holset-turbos-results-only-complete-installed-systems.html for complete install pics. That will get you some ideas. Yes there is alot of reading to do on the Holset threads but its worth it then these kinda of ?'s wont come up.:banghead:
