dsmlifestyle
- 80
- 4
- Aug 15, 2007
Dayton,
Ohio
I finally finished my HX35 install....well, kinda. I did some initial idle tuning and cruise tuning, using my old setup as the base. I made one WOT pull and quickly concluded that I am not finished with my purchases. The log showed ~51 lbs/min at 7100 rpm and still climbing with no knock. Well, this pretty much maxed the 2g maf out at ~3000 Hz (she stay pretty smooth, with only a SMALL ripple).
The upgrades include a HX35 from a 98' Dodge diesel, Delta 272 cams, DIY SS equal length manifold (fittings from Acestainless), new DIY 3" SS down pipe, DIY 4" intake, -16 AN drain (that was a pain in the ass), and an oil feed that uses a bypass for pressure control.
The bad: My EVO 8 fp is maaaxxxxxeeeeedddddd out, and she is still sitting in ultra 4x4 mode!
Oh, and my welding still needs work, but the down pipe came out pretty well, so it is improving.
